JustinT1010's avatar
JustinT1010
NETGEAR Nighthawk AC2100 MU-MIMO
Hi,
I just bought myself the NETGEAR Nighthawk AC2100 from Staples because I wanted a router with MU-MIMO capabilities. I did more research with this specific model and found out the “MU-MIMO” technology is only applied to the 2.4Ghz band of the router (shown within the products data sheet). Can anyone confirm if this is a typo? Would it matter if it was on the slower 2.4Ghz band rather than the 5Ghz band?
Thank you.
  • JustinT1010's avatar
    JustinT1010
    Dec 21, 2018
    The routers product page says that MU-MIMO is supported, but nowhere in the manual says it does, you are correct. It’s sad to see this router isn’t as I suspected, mainly because of the false advertising going on. I’ll be returning this product back to Staples today.
      JustinT1010
      • michaelkenward's avatar
        michaelkenward
        Hmm. Dodgy practice indeed.
        I see no sign that they have added this with a firmware update.
        Have you tried that?
