- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NETGEAR R6700v3 hardwire connection slows down with CAT6 compared to CAT5e
- Mark as New
- Bookmark
- Subscribe
- Permalink
As the title says, I have a strange situation with my download speed. I'm paying for 1gbps (gigabit) from Wave. For each speed I list here, I have tested it at least 2 times each on fast.com, speedtest.com, and google's speed test.
I have factory reset my router and reupdated to the latest firmware. QoS is off (if I turn it on, it slows down the speeds).
- When I hardwire my desktop into my Arris Surfboard SB8200 modem with my 50 ft CAT6 cable, I get ~900mbps, which is great!
- After I plug in my NETGEAR R6700v3 router to the modem using CAT5e, and my CAT6 cable for my desktop I get ~200 mbps
- If I swap the Router -> Desktop connection to a CAT 5e cable, my speed tests jump to 800 mbps down.
Are there known issues if a different cable is used from modem -> router, and router -> desktop?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NETGEAR R6700v3 hardwire connection slows down with CAT6 compared to CAT5e
Some devices are more sensitive than others to sketchy cat 5e cables. I'd be guessing that cable is boarderline.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try factory resetting the r6700. after the reset, during the install process,make sure to leave qos, access control, parental controls, and traffic monitoring all disabled
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did the factory reset and getting the same issue as before. Even with a CAT 5e cable, it's still ~200mbps slower (~500-600 mbps) than a direct connect of the Desktop to the Modem (~800mbps)
- Mark as New
- Bookmark
- Subscribe
- Permalink
How are you testing the speed?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Each time I test I do
- 2 tests on fast.com
- 4 tests on speedtest.net
- 2 on Whitesky Communications LLC
- 2 on Ziply fiber or another server
- 2 on Google Search's speed test
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried downgrading the firmware a version or 2
