Reply
NETGEAR SWITCHES FOR NAS (7960P NIGHTHAWK)
123RJS
Follower
ASKING COMMUNITY. I have small home NAS. I have NightHawk R7960P as Router behing 1G fiber gateway. My current 10/100 switches go to R7960P. These 1G swithces look good. I get higher speeds on my iPhone with its wi-fi connection than with the ethernet connections. Suggestions??
Message 1 of 3
microchip8
Master
Re: NETGEAR SWITCHES FOR NAS (7960P NIGHTHAWK)
If you need an unmanaged Gbps switch, it doesn't matter much which one you get. They're mostly the same inside. Get one with as many ports as you may need (or more)
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.89SF & Kamoj addon
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 16 TB
Message 2 of 3
Sound advice but might be better to go for "lots more".
These things have a habit of sneaking up on you. I had to go from 4>8>16
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 122 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
