Orbi WiFi 7 RBE973
Reply
NETGEAR X10 HT 160
xDecapture
NETGEAR X10 HT 160
Hi, I’ve noticed as a default and also as a option the HT 160 cannot be enabled as a feature, it’s greyed out as a option and cannot be selected.
Thanks in advance.
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 3
Accepted Solutions
xDecapture
Re: NETGEAR X10 HT 160
Thank you for your find I’ve had a read though, it looks like it’s not really currently supported as it should be quote;
“For now, this is a very expensive setup, without much gain in Wi-Fi speeds. When 160MHz support matures, we can expect a maximum throughput (goodput) of about 1300 Mbps in real life. ”
I guess NETGEAR have some work to do still unfortunately...
Message 3 of 3
All Replies
antinode
Guru
> Hi, I've noticed as a default and also as a option the HT 160 cannot be
> enabled as a feature, it's greyed out as a option and cannot be
> selected.
   I know nothing, but my Web search found:
      https://community.netgear.com/t5/x/x/td-p/1229568
      For 160MHz support - indeed there is no DFS channel support (North
      America) in current FW (1.0.1.36). Therefore, contiguous 160MHz
      bandwidth is not currently possible.  [...]
Message 2 of 3
xDecapture
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2747 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
