Reply
NEW Nighthawk X6 R7900 Second 5ghz band 1/2 speed of other 5ghz band
dpcharmin
Follower
I just started testing the performance of my new X6 R7900 router.  Testing with Speedtest I get very good performance from 5ghz band 1 but about half the speed from 5ghz band 2.  Any ideas or suggestions appreciated. Thanks
Model: R7900|Nighthawk X6 AC3000 Tri-Band WiFi Router
Message 1 of 2
Guru
Re: NEW Nighthawk X6 R7900 Second 5ghz band 1/2 speed of other 5ghz band
What modes are you using between each radio?
What channels are you using?
What security modes are you using?
Try single mode N and AC between each radio, WPA/AES.
What Mfr and model is the client wireless adapter your using to test with?
How are you testing the speed? Exnternal web site or LAN side file share? LAN side file share is preferred.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)> RBK953(v6.0.3.68) & XR450(v130)
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2176 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
