Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NEW R 7000 Firmware R7000-V1.0.3.60_1.1.27
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-06-09
04:26 AM
2014-06-09
04:26 AM
Link:
ftp://downloads.netgear.com/r7000/us/R7000-V1.0.3.60_1.1.27.chk
Just installed, first test was to stream hi-def audio from my server wirelessly and on another computer d/l a 2 gb file from the same server (all wirelessly). This always resulted in stuttering of my audio stream with every firmware to date. This firmware FIXES this!
Netgear thank you.......
CC
CC
Message 1 of 103
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-06-09
05:18 AM
2014-06-09
05:18 AM
Re: NEW R 7000 Firmware R7000-V1.0.3.60_1.1.27
Release Notes:
1. [Bug Fix] Fix a potential memory leak issue which could cause WIFI connectivity loss.
2. [Bug Fix] Fix a router reboot issue which is caused by an invalid DNS reply packet.
3. [Bug Fix] Fix Downstream QoS issue which impacts normal traffic like VoIP or VPN.
4. [Bug Fix] Fix a potential internet disconnect issue due to Bitcomet when it uses a large amount of network sessions.
Message 2 of 103
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-06-09
05:21 AM
2014-06-09
05:21 AM
Just installed it via router update. Can't be any worse for me than previous that meant I was only using 2.$ with no guest in an attempt to get some stability of connections.
Message 3 of 103
Retired_Member
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-06-09
05:43 AM
2014-06-09
05:43 AM
I'll be anxious to see if any of the folks having wired/wireless problems load this.
Message 4 of 103
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-06-09
07:39 AM
2014-06-09
07:39 AM
I'm sorry but isn't this already in a previous thread?
Message 5 of 103
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-06-09
08:22 AM
2014-06-09
08:22 AM
This firmware just came out. The other thread is for the .56 version, this is .60
I just updated because the wireless disconnect issue and WiFi <-> LAN traffic issue are still present in the .56 firmware.
This morning I wanted to browse the net from my cell phone and it was no longer able to connect to the local WiFi. Usually I reboot the router, but I logged in from a wired PC and saw the new firmware available. Once installed the router restarted so obviously my WiFi worked again. Now it is a "wait and see" thing. Hopefully this will at least fix the WiFi from not connecting and in a best case scenario will fix the loss of WiFi <-> LAN traffic.
Message 6 of 103
Retired_Member
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-06-09
09:46 AM
2014-06-09
09:46 AM
Keep us posted Xerses.
Message 7 of 103
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-06-09
10:10 AM
2014-06-09
10:10 AM
".60"
Sorry again but that is not the case. The .61 is available.
http://forum1.netgear.com/showthread.php?t=91503
Message 8 of 103
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-06-09
10:30 AM
2014-06-09
10:30 AM
Unfortunately, this is the same version that was discovered earlier, and doesn't have the Comcast IPv6 fixes. Still waiting for an official release with those fixes, then. Too bad.
Message 9 of 103
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-06-09
11:07 AM
2014-06-09
11:07 AM
Just updated. *crosses fingers*
Message 10 of 103
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-06-09
09:13 PM
2014-06-09
09:13 PM
RogerSC,
What issue are you having with Comcast IPv6?
Netgear R7000
DD-WRT Kong 24345
overclocked to 1.2 GHz
DD-WRT Kong 24345
Message 11 of 103
Retired_Member
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-06-10
06:16 AM
2014-06-10
06:16 AM
The problem may not be a Comcast only IPV6 issue, but most who have posted here looking for answers have Comcast.
The problem is when IPV6 is enabled, If you reboot or Power cycle router in will NOT get an IPV4 or IPV6 and release renew don't work. Unless you power cycle Modem. It also reverts to 6 to 4 tunneling and IOS devices and some other handhelds don't get IPV6.
This and the usage meter counting LAN as WAN have been confirmed as Bugs and should be addressed in next Official Update. The R6300v2 suffers from similar Bug too, Not sure what their plan is for it.
If you search IPV6 on this forum you should find plenty of post regarding IPV6. It's been a known problem for years and is finally getting attention.
Message 12 of 103
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-06-10
07:18 AM
2014-06-10
07:18 AM
I had similar problem with previous firmware,so I disable it!Is it fix with new firmware?
Nighthawk AX12[RAX120]
Nighthawk X10[R9000]
Message 13 of 103
Retired_Member
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-06-10
07:35 AM
2014-06-10
07:35 AM
No official release has the fix as of today. .60 no .61 if you can find it No.
Message 14 of 103
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-06-10
08:29 AM
2014-06-10
08:29 AM
@searay: I thought you said in .61 it was fixed? (However, .61 did seem to have beamforming issues.)
RBK53 v2
Router Firmware: 2.7.2.104
Satellite Firmware: 2.7.2.104 (Satellite1: Wired, Satetellite2: WiFi)
Setup: DSL Modem (Bridge Mode) - Personal Router - Orbi (Access Point mode)
Message 15 of 103
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-06-10
11:33 AM
2014-06-10
11:33 AM
ericnix wrote: What issue are you having with Comcast IPv6?
The issues that I was having with Comcast IPv6 were as searay mentioned above. When I had to reboot or power-cycle my router with IPv6 enabled, when it came back up it would have no internet connection. And when my desktop and laptop computers were able to use IPv6, neither my Android phone or iPad could.
With the current debug firmware that I'm using, both of these problems are now fixed. Unfortunately, the fixes were too late to make it into the latest official release. Should make it next time.
Message 16 of 103
Retired_Member
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-06-10
01:05 PM
2014-06-10
01:05 PM
.61 doesn't seem to exists anymore, so it's a moot point at this time. sorry if I confused the issue.
Message 17 of 103
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-06-10
06:40 PM
2014-06-10
06:40 PM
Thanks for posting about the IPv6 bug, guys - I thought I was going crazy. I'm on Time Warner and after a power outage a couple weeks ago I could not get the R7000 back online for the life of me, and of course their support line was busy forever so I gave up and reinstalled my previous router. Apparently it's not just a Comcast problem.
Last night I dug out the R7000 and put dd-wrt on it and it's working well so far. But now I know to try the Netgear code again once it's updated again. Thanks!
Message 18 of 103
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-06-10
08:52 PM
2014-06-10
08:52 PM
Sot3 wrote: Thanks for posting about the IPv6 bug, guys - I thought I was going crazy. I'm on Time Warner and after a power outage a couple weeks ago I could not get the R7000 back online for the life of me, and of course their support line was busy forever so I gave up and reinstalled my previous router.
There are a couple of ways to get the R7000 back online when this happens. One is to reset your modem. The other is to pull the WAN cable off the back of your router for 15 seconds or so, and then plug it back in. Sounds strange, but it worked for me.
Message 19 of 103
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-06-11
08:45 AM
2014-06-11
08:45 AM
I hope this resolves the dropped wifi issue. I've been dealing with netgear support for three months now. Its getting old. Routers should just sit there, not require constant attention.
Message 20 of 103
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-06-11
04:13 PM
2014-06-11
04:13 PM
Hi all. I've been using the R7000 in my pub for around a month and was rebooting it at least once a day to maintain LAN/WiFi connections (printers/iPad tills/Verifone VX680). Since the update though all seems well! Early days I know but this is the most stable it's been so far. Thought I'd let you know:)
Message 21 of 103
Retired_Member
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-06-11
05:15 PM
2014-06-11
05:15 PM
Good to hear, hopefully they can add IPV6 and fix the usage meter without going backwards.
Message 22 of 103
Retired_Member
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-06-11
05:56 PM
2014-06-11
05:56 PM
That's definitely good news. Hopefully Xerses has a similar report.
It would be really nice if this issue was finally fixed.
Message 23 of 103
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-06-12
03:33 PM
2014-06-12
03:33 PM
Spoke too soon sadly. Our primary iPad till gradually lost printers throughout the day, the slave till lost one printer about lunch time and our HP Officejet lost all connection around an hour ago. A router reboot has restored all connections. Will factory reset and re-flash tonight and report back. Damn.
Message 24 of 103
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-06-12
09:20 PM
2014-06-12
09:20 PM
So far the V1.0.3.61_20140605_QA firmware I have installed works well. I haven't lost my connections like I had been.
Although I did have my printer not using wireless due to other reasons. But I'll try turning that back on and see if it has problems.
Message 25 of 103
Top Contributors
User | Count |
19 | |
16 | |
9 | |
5 | |
4 |
