Reply
Highlighted
Novice
NEW R 7000 Firmware V1.0.2.194_1.0.15
Well, thanks NetGear, here we go again...just posted to the FTP server this AM. I will try as soon as I can get the time to flash and configure it, maybe later tonight. Let the testing begin.
Message 1 of 152
Highlighted
Novice
Re: NEW R 7000 Firmware V1.0.2.194_1.0.15
And here are the updates:
New Features & Enhancements:
•[Enhancement] VPN Auto Route support.
•[Enhancement] Separate Attached Device List for 2.4G and 5G.
•[Feature Change] 2.4G WIFI mode to "Up to 289Mbps" as default.
Bug Fixes:
•Fixed potential router GUI crash when accessing QoS page.
•Fixed iTune server airplay compatibility issue with Apple TV 6.0.
•Fixed the router GUI crash when using Genie v2.3.1.13.
•Fixed Bonjour printing with MAC OS 10.8 and 10.9.
•Fixed wireless device showing as wired device in attached device in AP mode
Message 2 of 152
Highlighted
Luminary
Exciting.
I have seen folks on this forum with V1.0.2.197_1.0.17 ... I wonder if the *_1.0.17 branch is the beamforming set of code?
I know a lot of folks are having a tough time with QOS. Even the DD-WRT folks seem to be having a tough time with QOS ... it appears NETGEAR has at least identified some issues and fixes here.
Thank you NETGEAR!
RBK53 v2
Router Firmware: 2.5.1.16
Satellite Firmware: 2.5.1.16 (Satellite1: Wired, Satetellite2: WiFi)
Setup: DSL Modem (Bridge Mode) - Personal Router - Orbi (Access Point mode)
Message 3 of 152
Highlighted
I just updated the firmware by manually checking the router update option and everything went smoothly. But, now the gui has a message that a router firmware update is available even though I have already updated it and verified the new version. When I click the status message it checks the firmware and comes back as negative (as expected).
I have power-cycled the router yet the message still stays. Will it go away on its own?
Message 4 of 152
Highlighted
Novice
I'm going to wait a while and see the report on this router. I'm still on 1.22 firmware since it's very stable for me but it's good to see Netgear keeping up the support on this router.
Message 5 of 152
Highlighted
I have the same issue of firmware update available but apart from that so far seems stable. Will have to wait and test more.
Message 6 of 152
Highlighted
Luminary
Please create a ticket ... I already have Smiley Happy
While obviously this is far from a show stopper ... if lots of folks create tickets ... hopefully that will further motivate NETGEAR to push out tweaks and fixes.
RBK53 v2
Message 7 of 152
Highlighted
I may have to if the issue persists. Apart from this minor annoyance, everything seems to be working fine.
Message 8 of 152
Highlighted
I've had the "firmware update available" message in the beta firmware for a while now.
The last 2 releases have displayed said message.
Message 9 of 152
Highlighted
I too have this problem. I've also discovered it's now dropping the 5Ghz ac connection on my Windows 8.1 laptop. Once the laptop goes idle, the connection seems to vanish and the only way to find it gain is to reboot the laptop.
The 2.5Ghz connection seems to be fine.
Message 10 of 152
Highlighted
Are the beamforming and airtime fairness checkboxes missing in this one?
Message 11 of 152
Highlighted
Luminary
Yes they are missing.
RBK53 v2
Message 12 of 152
Highlighted
Novice
Ah, well I have been on DD WRT 23075 and it is rock solid with multiple devices on both bands. BUT, I don't need QOS is my environment so I am not affected by that issue. I have not encountered one drop in service, but I reset to factory defaults, erase nvram, and 30-30-30 when I flashed.
One thing I saw on this forum was a reference to Steve Gibson's DNS benchmark. Worked good after DNS selections were made.
Message 13 of 152
Highlighted
I am considering purchasing this router for the USB3 port. I have an external usb3 enclosure I would like to attach to the USB port, so I will be able to access my content (photos, music, files) locally and remotely via the ipsec vpn server. I have read that enclosures with their own power supplies don't play nice with this router at the moment. Is this still the case, or was that issue resolved?
Message 14 of 152
Highlighted
I just went to Genie---Again an update---this time I shut down my Firewall and during the update a notification box comes up that Genie has to be replaced (ok??? why) and in the middle of the removal I get a failed again and asked if I want to ABORT yes, yes last time I had problems with Genie it left me with a WNDR4500 WITH NO FIRMWARE, and that is why I have r7000 NightHawk. I am beginning to be a bit SHY of GENIE.
Is anyone else having problems with GENIE AND DOWNLOAD/UPDATES????
Message 15 of 152
Highlighted
Novice
I can tell you this, I switched from DD WRT Linksys E4200 to NetGear WNDR4500 nearly 3 years ago. That appliance is still running in my daughter's house in San Diego. I have an R6300v1 running in our primary home. And, now at our condo in the city we work, I have the R7000. In each case, I bypassed Genie, and worked directly from the router IP. It is my belief, that my avoidance of many of the issue that has plagued users on this forum with these appliances, it the direct result of managing the routers without this software. I do not install it.
Message 16 of 152
Highlighted
aan1970, Yes I also see the firmware update in the user interface and I am not using the software. I have created a ticket with netgear and would recommend the same to you. The more the users report the earlier it will be taken care of in the next update.
Message 17 of 152
Highlighted
Agreed. I never use Genie, I just admin via the IP address.
Message 18 of 152
Highlighted
Prodigy
I was wondering if anyone has seen an improvement with this new firmware. I don't want to flash it in unless there is a compelling reason to install it. I know the text states there are fixes but do they work?
Message 19 of 152
Highlighted
I applied it last night and was getting a bit better performance than with the previous release. On my Nexus 5 802.11ac connection over 5ghz, I was getting 105Mbps down and 13 up. I'm not sure what the limit is since I only pay for 90Mbps down and 10Mbps up. ;-)
Message 20 of 152
Highlighted
After this update, my 5Ghz band is very stable. However, I am getting frequent 2.4Ghz disconnects on my Galaxy Tab 10.1 2014.
With the previous firmware, the 2.4Ghz band was very stable but I got frequent 5Ghz disconnects on both my Galaxy Note 3 and my Galaxy Tab 10.1 2014.
Overall, the latest firmware is "better" for me because I would rather have a stable 5Ghz band than 2.4Ghz.
Message 21 of 152
Highlighted
Prodigy
Maybe I'll just stick with the stock firmware for now. I'm not using 5 GHz but I am using 2.4 GHz. I was hoping for better 2.4.
Message 22 of 152
Highlighted
I streamed video for several hours over 2.4ghz last night without an issue. I have not seen any 2.4ghz issues.
Message 23 of 152
Highlighted
Is anyone using a NAS with this router. I was wondering what speeds are you getting using wifi at both 2.4 and 5GHz.
Message 24 of 152
Highlighted
So last night my main pc that's hard wired to my R7000, started having long delays on page requests and other web based applications started dropping and reconnecting. So I cycled power on my modem and router and it was still acting flakey. I was reading thru the thread and saw someone mention Steve Gibson's DNS benchmark. Is that something I should look into, I'm not sure if it pertains to the router or my ISP's DNS's. Logged into my router and performed the firmware update and still having delays when pulling up pages."still see the firmware update available, but leads to no update avaialble,will put in ticket*". Even my speed tests start strong then drop then shoot back up. Any one else come across this or recommendations??? Thanks!
Message 25 of 152
Top Contributors
Discussion stats
Announcements
