Reply
NH X6 - after firmware update cannot connect to USB
saucerman
so I downloaded the lasted firmware V1.0.4.68_10.1.7, on my router, now I cannot connect to my USB shared drive...it was mapped to a Y drive and now it says An error occurred which connecting - the network path was not found.  I have no idea how to resetablish the connection...
any points in the right direction would be most helpful
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 4
Guru
Re: NH X6 - after firmware update cannot connect to USB
Are you able to see/access the drive from the router's settings?
The question comes down to if you just need to remap to the y: drive to get it working or if something went wrong on the router side.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 4
saucerman
The router does not recognize the USB drive, even after a reboot or switching ports...the works just fine from any of my computers
Message 3 of 4
Guru
How are you determining this?
Are you logging into the browser gui to view/see it?
Did you try factory resetting the router and  reinstalling it?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 135 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
