Reply
NIGHTHAWK R8000
RH222
Follower
NIGHTHAWK R8000
Can you be on an i phone connected to a wireless network and an i mac connected to the same wireless network and the the person on the other end of the phone line see what you are doing on the computer?
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 4
William10a
Master
Re: NIGHTHAWK R8000
You should not able to as each  device would have it's own ip address why do you ask do you think some one is see what you do on your computer?
Message 2 of 4
mondenath
Prodigy
Re: NIGHTHAWK R8000
Both can see each other devices IP provided who controls the router. But not like remote access unless network share or some kind of sharing enabled.
if it concern on you privacy issues dont worry you are safe.
Message 3 of 4
William10a
Master
Re: NIGHTHAWK R8000
I may have  misunderstand the posting some I was thinking that they were concerted about someone seeing there key storkes
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2365 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
