Reply
NIghthawk R7000 as repeater/extender
Redguitar
New location and R7900P is in a remote location with no wired access. Trying to setup as a repeater but cannot find repeater option under advanced tab. Is this not an option for me?
Message 1 of 5
microchip8
Master
Re: NIghthawk R7000 as repeater/extender
Repeater mode is not available for this model. Use Access Point if you can pull a cable. If no cable is possible, you can use powerline
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.88SF & Kamoj addon
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400 - Cruncher: Intel Core i5-7400
Message 2 of 5
Redguitar
Please excuse my ignorance, powerline?
Message 3 of 5
DarrenM
Sr. NETGEAR Moderator
Powerline lets you run ethernet connection over your home powerlines
https://www.netgear.com/home/products/networking/powerline/default.aspx
DarrenM
Message 4 of 5
Your subject says R7000 but then you talk about R7000P. They are not the same.
For the R7000, try WDS in the manual:
>>>> R7000 | Product | Support | NETGEAR <<<<
"The router can act as router a wireless base station or a wireless repeater in a wireless distribution system (WDS). A WDS expands a wireless network through multiple access points."
Is that what you want?
If it is the R7000P, then @microchip8 is spot on. Also with the Powerline Ethernet suggestion. I use that to fed an Orbi in AP mode:
Powerline Networking | Powerline Ethernet | NETGEAR
Uses the mains circuit instead of stringing LAN cables all over the place.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1238 views
  • 2 kudos
  • 4 in conversation
Announcements
