Reply
NVRAM Erase
dmystic1
Apprentice
NVRAM Erase
Anyone know how to force clear NVRAM on R9000?  For whatever reason doing a 30 30 30 still bring the router back up with the password I changed it to.  Also for some reason I can't pull an IPv6 address anymore with router.  If I connect my computer direct to the modem it works fine.
Message 1 of 2
TheEther
Guru
Re: NVRAM Erase
You should only need to push the reset button for about 10 seconds until all of the lights flash on and off.
You can also clear settings in ADVANCED > Administration > Backup Settings.  Click Erase.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 7444 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
