Orbi WiFi 7 RBE973
Need Circle Passcode
scottrussell01
I recently went to make changes to my Circle account and the app required me to sign in again and need a passcode. My phone is the only phone number I would have used when setting up Circle, but I didn't receive a passcode when I asked it to send me one. Is there some other way to receive a passcode?
Message 1 of 12
Accepted Solutions
Christian_R
NETGEAR Employee Retired
Re: Need Circle Passcode
Hi Scott,
Click on my name and it should bring you to my profile where you should be able to send me a private message.
Christian
Message 5 of 12
All Replies
mdnc_617
I am having the same issue.
Message 2 of 12
Christian_R
Hello scottrussell01 &mdnc_617,
I will need the following info so that I can validate and retrieve the passcode from our system. Please send me the requested info in a private message.
Name:
Email:
Model Number:
Serial Number:
Thanks,
Christian
Message 3 of 12
scottrussell01
I cannot figure out how to private message you Christian
Message 4 of 12
Christian_R
Hi Scott,
Christian
Message 5 of 12
FR1978
having the same problem....new phone
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 6 of 12
DK12103
How is this helpful to the community if it is make this private,   many people including myself are have the same problem?  I'm stuck with putting in a passcode that I can't receive.     I can't set this up and there is nothing online on how to solve this.
Message 7 of 12
mishravaibhav
How do i reset my Circle password as my phone number has changed.
Message 8 of 12
thermorex
I have the same issue, I created the Circle 1st Gen account, and when I tried to log in as an admin, I cannot receive the code via text (SMS) - have tried multiple times to request it - and there is no way to reset Circle to start all over again or to be able to log in (since the text/SMS does not reach the phone #, So I get stuck at the screen with "enter passcode".
Is there any way this can be fixed?
Thanks a lot!
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 9 of 12
Capamrica22
I need an pass code for Circle.  Its not sending an SMS to my phone.
Model: R7000|AC1900 Smart WIFI Router
Message 10 of 12
SJ29
Model: R6120|AC1200 Dual Band WiFi Router
Message 11 of 12
Christian_R
Hello Circle Users,
If you are having issues logging in Circle and require a passcode, I will need the following info so that I can validate and retrieve the passcode from our system. Please send me the requested info in a private message.
Name:
Email:
Model Number:
Serial Number:
Thanks,
Christian
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 6146 views
  • 2 kudos
  • 9 in conversation
Announcements
Orbi WiFi 7
