- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Need Help Understanding what the Blinking LEDs mean in the bootloop (NETGEAR X6 R8000)
- Mark as New
- Bookmark
- Subscribe
- Permalink
So, pursuant to this thread, I took a footage of the blinking LEDs on both of my NETGEAR routers.
Details of both routers, including their respective firmware versions are available in the thread link above.
I hope the video below will shed new light (pun not intended) on what is causing the bootloop, and how exactly to get out of it.
The video is as follows:
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
So the USB-Serial cable arrived in my mailbox yesterday.
Got into the router via a terminal window (Mobaxterm), reflashed the firmware to a lower level (v1.04.28) and did an nvram erase. Seems there's a bug in the latest version (v 1.04.46) that causes the nvram to fill and not be able to clear it on its own.
Got both routers working in a normal state, although one of the routers keeps dumping
Magic bitmask 0x1985 (and other addresses) not found at 0x043a0010 (and other addresses): 0x4c18 (and other addresses) instead error, which lengthens the boot time.
Wireless performance has also dropped significantly but it's better than leaving it as a brick, i guess.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Need Help Understanding what the Blinking LEDs mean in the bootloop (NETGEAR X6 R8000)
For reference, one of the routers starts to bootloop at the 1:30 mark.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So... no one can provide an explanation for these LEDs or has come across these LEDs before?
Would a USB to serial procedure/TTY with an erase NVRAM or firmware reflash "unbrick" the router(s)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Bumping up this thread to see if anyone else has experienced a similar problem (with this pattern of lighting) and can provide an explanation as to why the router keeps rebooting like this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Issue still remains unresolved. Continuing to look for answers on this forum.
My shipment on the Serial cable for this router has been stuck since end of February due to delays caused by COVID-19, would appreciate if anyone here has alternative solutions in the meantime.
- Mark as New
- Bookmark
- Subscribe
- Permalink
