- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
(Need help) debrick unresponsive R6900v2
- Mark as New
- Bookmark
- Subscribe
- Permalink
I need help debricking a r6900v2 because of a failed software update
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I give up I'm buying a link router from your competitors and using ddwrt.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: (Need help) debrick unresponsive R6900v2
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
- Mark as New
- Bookmark
- Subscribe
- Permalink
tftp: can't read from local file 'R9000v2-V1.2.0.88.img'
- Mark as New
- Bookmark
- Subscribe
- Permalink
did you follow the instructions precisely?
And make sure the file was extracted to the proper location?
If its not reading it, either its not extracted, not in the proper location, or your path/file name isn't correct.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I followed the instructions percisely!
Yes, It was extracted using 7-zip and the file placed on the desktop, I changed the directory to one drive on win 10.
If my pathway file name was not correct then how do I fix it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tough to know how to fix it when we can't see what you're typing into the command line or where the file is located. The command line requires you type it exact to the location and the file name. Thats why the video can help at times.
Have you tried using an earlier firmware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you get any responses to the commands you entered?
They can point to possible problems.
This process depends on timing and can take several attempts.
Don't give up. Keep trying and pay attention to the responses you get.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here's my screenshot of my cmd on win 10.
- Mark as New
- Bookmark
- Subscribe
- Permalink
2 things to try.
1. put the actual file on your desktop and not the onedrive.
2. rename the file name to something simple. This keeps simple errors from causing the issue.
Again, make sure you extracted it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also I'm seeing different models throughout your post. I've seen r6900, r6900P, R9000
Ensure the version of firmware is for your matching device. Look at the label on the route to confirm.
- Mark as New
- Bookmark
- Subscribe
- Permalink
One drive is my desktop. The desktop command doesn't work on win 10 no more on cmd when I do it and my win 10 is fully updated. The folder is extracted as well and I could not find the model number on here and on the router it says R6900v2 |Nighthawk AC1900 Smart WiFi Dual Band Gigabit Router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
both my windows 10 and 11 devices have a standard desktop and the "onedrive desktop".
I can open/access either from my terminal.
Try it on the standard or even in the standard documents folder.
It shouldn't matter but its better safe than sorry. Especially when you're getting that notice.
Again, also try renaming it so you're sure it isn't an extra character/space/misspelling causing the issue.
You could simply call it r6900 . img
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is promising what cmd did.Instead of not recognizing the file directory I placed the file in one drive directory and it gave the output saying the TFTP transfer fails with error Connect request failed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
you could always try the other tftp methods. I've used tftp2.exe found in various sites. I reccomend watching a few videos on youtube on "how to debrick a router" which will tell you the steps to try unbricking your router. You'll need to change a few things on your IPv4 on your ethernet connection to make the tftp2.exe on your computer so I recommend you watch the youtube videos.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
and it said it was an invalid file or what error did you get?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Could not connect to server I used tftp2.exe and did the ethernet config to static and disabled my wifi adapter.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What do I do now then?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
How do I use this ? Like what do I install?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do I use command prompt to use nmrpflsh? What do I type in?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Reflex101 wrote:
....I'm buying a link router from your competitors
We do not have "competitors". You seem to be under the impression that the people who answered your questions work for Netgear. They don't. This community is essentially a user-to-user venue with some input from a small band of Netgear techies.
@Reflex101 wrote:
...using ddwrt.
That might not be a good idea. Alternative firmware suppliers often require you to use something like TFTP, which does not seem to be something that comes easy to you.
