Reply
Need help pls
Retired_Member
Not applicable
Need help pls
i just got my xr300 today and i have no idea about bridge mode. I don't know how it work
can i use xr300 with my family xfinity modem/router combo without putting in bridge mode for gaming ps5.
using xr300 without bridge mode ,will it causing problem with xfinity wifi? i can’t the disable xfinity wifi because my family want to use xfinity wifi but it too slow for my ps5. . can i use xr300 without putting in bridge mode
sorry about  my English.
Model: XR300|Nighthawk Pro Gaming Router
Message 1 of 9
Retired_Member
Not applicable
Re: Need help pls
Help pls
Message 2 of 9
Guru
Re: Need help pls
what actual gatewa is it from xfinity?
 did you try putting the netgear IP address into the xfinity's dmz?
or putting the netgear into access point mode
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 3 of 9
Retired_Member
Not applicable
Re: Need help pls
Xfiniity TG1682G'
Message 4 of 9
Guru
Re: Need help pls
Message 5 of 9
Retired_Member
Not applicable
Re: Need help pls
I can't access dmz on xfinity
If i put xr300 on ap mode. Can I use all the features that the router have . Like gaming features.
Message 6 of 9
Guru
Re: Need help pls
No you wouldn't.
So your options are this.
1. keep the double nat setup you have.
2. figure out how to to put the Netgears IP address into the xfinity's DMZ (try calling xfinity for help with this)
3. put the netgear into AP mode and miss out on some features.
its a problem of cascading routers
Message 7 of 9
Retired_Member
Not applicable
Re: Need help pls
i have double nat on ps5. is it safe to keep double nat on ps5. can i play with other player. if i have double nat i can access the router features gaming
Message 8 of 9
Guru
Re: Need help pls
If you're using both in router mode, the dumaOS router won't function as well as it can.
I don't have a majic means of fixing it. you know what your options are (outlined earlier).
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 297 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
