Reply
Need to forward a url to another IP..
Raycaster
Follower
Thank you for any help.
I have a Logitech TV HD Cam for skype that no longer works due to the Microsoft buyout etc.
Long story short, the unit is never able to ping www.skype.com anymore and fails its internet check rendering the device un-useable.
The work around I found is:
Solution:  If you have a router / firewall / own administered DNS Server, create an entry www.skype.com and direct it to an other IP-Address which you can ping (e.g. your own default gateway)
Is this possible with the r7000?
Again, thank you for your time.
Message 1 of 2
ElaineM
NETGEAR Employee Retired
Re: Need to forward a url to another IP..
Welcome to the community, @Raycaster
I think you're referring to this workaround from Skype's website.
Based from the step, you will need to change the LAN IP address of the router to 204.9.163.248.
In order to do that, you will need to access the admin page of the router.
Once you are inside the admin page, you will then need to go to Setup > LAN Setup and change your LAN IP from there.
ElaineM
NETGEAR Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2041 views
  • 0 kudos
  • 2 in conversation
Announcements
