Reply
Highlighted
Follower
Nest Home wont connect to Nighthawk R7000
Trying to set up a new "Nest home doorbell/camera" conneting into my R7000.
It finds the router and i can see the device when signed in as Admin.
It won't connect to the router. (plenty of signal strength and no problems with anything else connecting to it.)
However, it will connect to other routers including my Verizon Jetpack.
The fail happens during Nest Home setup when I get to the step where I enter the WiFi password. (yes the password is correct)
I'm not sure how to resolve this or how to troubleshoot.
Thanks for any advice.
Dave
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 2
Highlighted
NETGEAR Moderator
Re: Nest Home wont connect to Nighthawk R7000
Have you tested the router by removing the password and then connecting the Nest device or even activating the guest network and connect it to that?
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 379 views
  • 0 kudos
  • 2 in conversation
Announcements
