Orbi WiFi 7 RBE973
Reply
Net gear orbi WiFi system mesh system
Cman93
Follower
Does it cost to use/hookup this system.I got It at wal mart.Not much for instructions in the box,sounds like you do.
Message 1 of 3
Guru
Re: Net gear orbi WiFi system mesh system
What Orbi system are you referring to?
Netgear has set up a community forum specifically for the Orbi AC products. Most of the people who watch that forum are more likely to have experience with Orbi and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi/bd-p/Orbi for Orbi AC systems
or https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax for Orbi AX systems
or https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable for Orbi with built in Cable Modem systems.
Message 2 of 3
Guru
No it doesn't cost to use/hookup a orbi system.
There are added in things you can subscribe to like netgear armor/circle/etc.
But nothing you're required to do.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 371 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
