Reply
NetGear Dead Spot Terminator - Does not work!
990james
Follower
I recently bought a NetGear Dead Spot Terminator. After it got unplugged it has not worked. The wifi router works just fine, but when the DST is on it shows up in my list of internet access points, but when I connect it shows nothing and says "No Network Connectivity." What do I do?
Message 1 of 2
JamesGL
Master
Re: NetGear Dead Spot Terminator - Does not work!
Hi 990james,
What is the model number of your router? Make sure it is the R7300. It will only work with that model. If it is the R7300 check the KB article below.
http://kb.netgear.com/app/answers/detail/a_id/29922/~/adding-a-dst-adapter-to-an-existing-dst-networ...
JamesGL
Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2756 views
  • 0 kudos
  • 2 in conversation
Announcements
