Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NetGear R8000 openvpn warnings can't solve
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-05-16
04:36 PM
2021-05-16
04:36 PM
Hi,
I can connect to Negear R8000 with Openvpn 2.5.2 but receive 2 warnings that I can't seem to shake. Tried adding and removing different lines/commands to the config.ovpn file with no success. Can't seem to find a solution. I have latest router firmware, but maybe Netgear needs to release new firmware?
Any thoughts?
1.)WARNING: No server certificate verification method has been enabled. See "http://openvpn.net/howto.html#mitm" for more info.
2.) ROUTE: route addition failed using service: The parameter is incorrect. [status=87 if_index=36]
client
dev tap
proto tcp
dev-node NETGEAR-VPN
remote ip.address 12974
resolv-retry infinite
nobind
persist-key
persist-tun
ca ca.crt
cert client.crt
key client.key
cipher AES-128-CBC
comp-lzo
verb 5
mssfix 1430
auth-nocache
route-gateway 192.168.1.1
Message 1 of 1
Announcements
