Reply
NetGet NightHawk X6 AC3200 R8000 - OpenVPN - MD5
BuzzettiMartin
Initiate
Good night, I have a NetGear NightHawk X6 AC3200 R8000 with the firmware 1.0.4.12 installed, the lastest, and I can confirm that no change has been made to the VPN certificate, even though this was known at least since January 2018 when a NetGear Moderator indicated that NetGear was going to support the new certificate before OpenVPN stops supporting the MD5 certificate (April 2018). Here is the post I refer to:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R8300-Support-for-MD5-Certificates-with-Buil...
I insist to NetGear to solve this problem in the following days and fulfil with their word. This is a complete lack of respect to their clients and users, and I would not stand at all this situation. If necesary, I will take al necesary means to make sure that this problem is finaly resolved.
Thanks in advance.
Yours sincerely, Buzzetti Martín
Model: R7900|Nighthawk X6 AC3000 Tri-Band WiFi Router
Message 1 of 3
Accepted Solutions
Altsai
NETGEAR Expert
Re: NetGet NightHawk X6 AC3200 R8000 - OpenVPN - MD5
here comes the newer FW v1.0.4.18 can support SHA256 based certificate~~
https://kb.netgear.com/000058796/R8000-Firmware-Version-1-0-4-18
Message 2 of 3
All Replies
Altsai
NETGEAR Expert
Message 2 of 3
BuzzettiMartin
Initiate
Thanks Altsai.
May I notice to NetGear that we are not friends, we are clients. If its necesary, we will sue you in order to asure you fulfill what you promises.
Yours faithfully, Buzzetti Martín
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2323 views
  • 1 kudo
  • 2 in conversation
Announcements
