- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear Advanced settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
I want to turn on AP Isolation for better security, how to set it?
Is there anyway to change router username 'admin' to something else
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@sutedy wrote:
Do i have to turn on guest network? I afraid it will slow down and load router unnecessary since no one will use guest network.
If you want isolation with the stock firmware, then you need to use the guest network instead of the normal network.
There wouldn't be any noticeable slowdown, just a bit of extra broadcast traffic. If you want everything isolated, then you can hide the SSID on the main network (I don't think you can turn the main network off but keep guest running).
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear Advanced settings
If you meant "prevent wireless clients from reaching the home network" by "AP Isolation" then the way to do that is to only turn the guest network, and make sure the box next to "allow guests to see each other and access my local network" is unchecked.
- Mark as New
- Bookmark
- Subscribe
- Permalink
How to enable AP isolation in other way
https://www.rickygao.com.au/blog/shibby-tomato-configuration-details/
AP Isolation | This isolates all wireless clients and wireless devices on your network from each other. Wireless devices will be able to communicate with the Gateway but not with each other in the network. |
- Mark as New
- Bookmark
- Subscribe
- Permalink
