Orbi WiFi 7 RBE973
Reply
Netgear D7000v2
forry
Initiate
Netgear D7000v2
After I lose power on My Nighthawk D7000v2 e.g. a minor power cut, or If i unplug it from the mains, l always lose the internet. The router reboots and looks normal  but there is no internet connection. It's not automatically reconnecting. It only does so, when I go into the router and into the advanced tab and select internet setup and click on apply. Only after doing so, then the internet connection comes up. It is set to auto detect. I'am using this as a fibre router and not copper broadband settings.
Any Help appreciated
Message 1 of 2
Accepted Solutions
forry
Initiate
Re: Netgear D7000v2
I think I have found the fix. I changed a setting. So I went to setup.Under Wan Preference,I changed the setting from Must use DSL Wan to "Must use Ethernet Wan".Click apply.
So to test it I turned the modem off  and repowered the device. And I  noticed the  internet connection on the router came back automatically.Yay.
Message 2 of 2
All Replies
forry
Initiate
Re: Netgear D7000v2
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1096 views
  • 1 kudo
  • 1 in conversation
Announcements
Orbi WiFi 7
