SurXen_Steven
May 18, 2021Follower
Netgear Genie login
Hello, Fellow Netgear Router users!
I've recently trying to access the Router's genie page. I have been having trouble and I forgot my password so I performed a Factory Reset.
It still asks me the security question which I forgot. The warranty for me experied less then a year ago. How can I perform a factory reset, and use the default Username:"admin" and Password: "password" and access the genie page?
Thank you.
1 Reply
- DarrenMSr. NETGEAR Moderator
You may want to try this KB see if that will let you skip that step and use the default login.
https://kb.netgear.com/978/Completely-avoiding-the-Smart-Wizard
DarrenM
