Orbi WiFi 7 RBE973
Reply
Netgear Genie not available on Play Store; only nighthawk but DGN2200v4 not supported
Hello and thank you for looking at this.
I used to be able to login to my DGN2200v4 router via Genie on my android phone but Genie is no longer available to install.
I'm directed to Nighthawk, but it doesn't support my router.
Is there an alternative app I can use please?
Thanks in anticipation.
Model: DGN2200v4|N300 Wireless ADSL2+ Modem Router
Message 1 of 4
Accepted Solutions
Guru
Re: Netgear Genie not available on Play Store; only nighthawk but DGN2200v4 not supported
Message 4 of 4
All Replies
Guru
I believe Genie is not being developed anymore thus NG is pushing users to the Nighthawk app.
You may want to post about this over in the Genie forum:
https://community.netgear.com/t5/Genie/bd-p/home-genie
Thank you.
Message 2 of 4
Thanks, I'll try that.
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 991 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
