Reply
chexTLG
Follower
Netgear Night Hawk R7500 QOS speed test issue
i have problems with enabling the QOS as the speed test keeps failing even with all devices off and disconneted for the speed test to take place it is on firmware v1.0.0.130 and says thats up to date any suggestions how this can be resolved so i can enable QOS
Model: R7500|Nighthawk X4 AC2350 Smart WiFi Router
Message 1 of 3
DarrenM
NETGEAR Moderator
Re: Netgear Night Hawk R7500 QOS speed test issue
Have you tried to load another firmware and then try the QOS?
DarrenM
Message 2 of 3
Zman0729
Evidently, this issues has not been resolved? I have the same issue.
Speedtest works fine when performing it online. Then, after router log-in, failure everytime. After repeated attempts my frustration mounts. I then reset it to factory defaults, and tried again before the firmware update which also yielded the same results.
Can someone help out?
Model: R7500v2|Nighthawk X4 AC2350 Smart WiFi
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 224 views
  • 1 kudo
  • 3 in conversation
Announcements
