Orbi WiFi 7 RBE973
Reply
Netgear Night Hawk
lowman
Netgear Night Hawk
Has any one tryed and SSD in a drive enclouser with the R 8000 . The unit will power from the usb on the router  . I had a smaller usb Seagate expansion drive that worked with no issues but want to upscale to larger capicity and  speed and not sure if the router will power it .
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 5
Accepted Solutions
JamesGL
Master
Re: Netgear Night Hawk
Hi lowman,
The KB article below is the list of the drive that has been tested to work with the router. If it is not on the list, you may try it but it may or may not work. For higher capacity drives, it may need to have its own power adapter since the router will not be able to provide enough power for the drive to work.
http://kb.netgear.com/app/answers/detail/a_id/18985/~/readyshare-usb-drives-compatibility-list?cid=w...
JamesGL
Community Team
Message 4 of 5
All Replies
You can try and let us know how it is handeling itself!
Message 2 of 5
lowman
Thanks for nothing  I was looking for some on who already tryed it not a curt answer like yours . I did give it a try now try it for your self and see if you brick your 300 dollar router .
Message 3 of 5
JamesGL
Master
Hi lowman,
JamesGL
Community Team
Message 4 of 5
JamesGL
Master
Hi lowman,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2149 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
