Reply
Netgear NightHawk R8000 Wifi not working Yellow warning
julian28
Hello everyone and Merry Chrismas. So while cleaning up my desk, I turned off my Nighthawk and when turning it on The wifi does not work.
All ethernets ports are working, and I can use my desktop for the internet.Also when I connect to my IP network genie thing, it says wifi Off with a yellow warning thing ( pictures )
Things I've done
Rest my router many times
I held the button to rest for 7 sec and it rest everything
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 5
antinode
Guru
Re: Netgear NightHawk R8000 Wifi not working Yellow warning
   What do the LED indicators indicate?
> Things I've done
   Operate the "WiFi On/Off button with LED"?
   Visit http://www.netgear.com/support , put in your model number, and
look for Documentation.  Get the User Manual.  Look for "Top View".
Message 2 of 5
julian28
All Led looks like it works
 5g and everythng
Message 3 of 5
antinode
Guru
   And all of your old settings were lost (including the SSID and
passphrase credentials)?  I'd expect that to re-enable the wireless
radios.  Under ADVANCED > Advanced Setup > Wireless Settings, are all
the "Enable Wireless Router Radio" boxes checked?
   I'd expect the BASIC > Home status to agree with the LEDs.  If they
did not, then I'd try a full ("factory") reset.  But, if you actually
do that, and the thing stays inconsistent, then you might have a
hardware problem.
Message 4 of 5
TerryPh
Virtuoso
DO YOURSELF A FAVOR. DOWNGRADE THE FIRMWARE TO 1.0.3.54 THE PROBLEM WILL BE SOLVED. UNTIL NETGEAR FIXES IT UP
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1565 views
  • 0 kudos
  • 3 in conversation
Announcements
