Orbi WiFi 7 RBE973
Reply
Netgear Nighthawk AC 2100 Link Aggregation supported?
listedguru
Tutor
How do I tell if my router supports Link aggregation? I have a 3ish year old Nighthawk AC 2100 and would like to utilize link aggregation via my Netgear CM1100 cable modem. Does my router support this?
Thanks,
-Guru
Message 1 of 4
microchip8
Master
Re: Netgear Nighthawk AC 2100 Link Aggregation supported?
No
Message 2 of 4
Guru
@microchip8 is correct. It doesn't support link aggregation.
do you pay for speeds over 1 gigabit? If you don't, I wouldn't worry about it.
If you do, are the devices needing that speed hardwired in? Because wireless isn't going to max out gigabit.
I didn't notice a single change when my isp when gigabit to 1.2 gig and I have a fairly extensive setup for running it.
Message 3 of 4
listedguru
Tutor
Thank you for the info. The only device that I have hardwired in that could take advantage of gig+ speeds would be my pc but I would need to install a new network card. I just figured if my router supported link aggregation it might be worth it. No big deal. At this point I'll wait until I decide to make the move to a wifi 6 router. In the meantime if it ain't broke...
Thanks,
-Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 570 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
