Reply
Netgear Nighthawk AC2600 Smart WiFi Router as Repeater
TTinker5
Follower
Is it possible to setup my R7450 as a wifi repeater? I've logged into the router and looked under Advanced Settings but I do not see an option for Wireless Repeater.
I am using a Nighthawk AC1900 Wifi Cable Modem Router as my bass. As I also have the AC2600, I would like to try to use it to extend my wifi if possible.
Model: R7450|Nighthawk AC2600 Smart WiFi Router
Message 1 of 3
microchip8
Master
Re: Netgear Nighthawk AC2600 Smart WiFi Router as Repeater
Not supported by stock firmware. You also don't want to use repeaters as they cut bandwidth in half due to constant need to be in contact with the main router
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.88SF & Kamoj addon
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 16 TB
Message 2 of 3
You can use it as a wireless access point (AP), wired back to your router.
That would also work on the end of a Powerline network.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 699 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 6E
