Reply
Netgear Nighthawk R7000 firmware update
bchmn
Follower
Is it a problem that I updated firmware directly to the router rather than to my pc.  When initially setting it up, I saw a firmware update was available and initiated the update but later saw it is advisable to download it to pc and then upload it to the router.  Can I leave it or is there something I should do?  Thanks, Ray @ bchmn@msn.com
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 3
microchip8
Master
Re: Netgear Nighthawk R7000 firmware update
you can update the firmware when the router reports there's a new version. On the Firmware Update page there's a button for that. You can also download and unzip the firmware the load it up. I strongly recommend doing firmware updates with a wired PC and not some phone app over wifi
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.88SF & Kamoj addon
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400 - Cruncher: Intel Core i5-7400
Message 2 of 3
scjay
If it running okay after the update then you don’t need to do anything else. The only thing I would suggest would be to turn off automatic updates if it got turned on by the update you installed.
Jay
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 705 views
  • 0 kudos
  • 3 in conversation
Announcements
