Orbi WiFi 7 RBE973
Reply
Netgear Nighthawk R7000 in Bridge mode + Wireless - Not working anymore
remd
Initiate
I have setup a R7000 in Bridge mode about 5 years ago and it was working fine including the Wifi network. I need this as I have a PFSense router that handles all settings and ips in the network.
I recently had some issues as a neighbour started using the same wifi channels as mine on 2.4ghz and 5ghz so I wanted to set the R7000 on other channels, but I couldn't access the R7000 anymore as it was in bridge mode (no https or other port to logon) so I end up resting it and doing the bridge configuration again.
I was able to modify the wifi channels and setup the R7000 again but as soon as I set it in Bridge mode it cuts the Wifi, although it seems to be configured in the Wireless bridge settings.
I have also updated to the latest firmware when it didn't work anymore but although the menus changed a bit the results was the same ?
So I don't know why it has been working for he past 5 years and I cannot get it to bridge to Wifi anymore, Does anyone know what I might be overlooking ?
Thanks!
Message 1 of 4
Accepted Solutions
remd
Initiate
Re: Netgear Nighthawk R7000 in Bridge mode + Wireless - Not working anymore
thanks for your reply. I am on the latest R7000 firmware, just downloaded it from Netgear.
I got it to work, what I needed was the "AP Mode" not the Wireless bridge mode, the naming changed with the firmware update and got me confused.
So all good now
Message 3 of 4
All Replies
Guru
What FW are you using?
When the R7000 is in Bridge mode, this mode is a wireless client bridge mode only. Means that the R7000 becomes a wifi client that needs to connect to a source wifi SSID signal. In this mode the R7000 will not broadcast a wifi signal for other devices to connect too.
I have mine in this mode right now and it's working as a client wifi device connected to my main Orbi system. A pc and game console connect to the R7000.
Message 2 of 4
remd
Initiate
So all good now
Message 3 of 4
Guru
Glad you got it working. Yes AP mode would be the one.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 9196 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
