- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear Nighthawk R8000 X6 AC3200
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Netgear Nighthawk R8000 X6 AC3200
First thought is to check that the power supply is still good.
Do you have a spare that delivers the same amps and volts? And old Netgear power supply would work.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I don't have an extra 17v power supply. I did check the power cord by changing it to a different recepticle but it powers up, lights flash then fade away. I'm probably going to BestBuy to put another one and use the power cable from that one to see if it solves the problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
17V doesn't look right. Did you mean 12V?
Just another user.
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I know nothing, but a quick glance at the User Manual, "Figure 5.
Router label", page 16 (or the actual label on the router), might be
more productive than random guessing.
When in doubt (which should be always), take your own advice, visit
http://netgear.com/support , put in the model number, and look for
Documentation. Get the User Manual. Read. (_Then_ start guessing.)
