Reply
Netgear Nighthawk router no orange lights
Cajundan2020
Follower
Orange lights went white.  Having trouble getting the internet to stay on.
Netgear 87      AC 2300 smart wifi     R7000P
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 3
Guru
Re: Netgear Nighthawk router no orange lights
Which lights? There's a bunch of led's on it. go to the netgear.com/support/   type in your model. it'll take you to the manual that has what each led is and what it means.
What modem are you using?
What firmware is on your router?
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 3
And?
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
Look for the model number on the label on the device.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 317 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
