Orbi WiFi 7 RBE973
Reply
Netgear Nighthawk x4 ac2350
craigressler
I want to know if the Firewall (s) on the Nighthawk x4 ac2350 model R7500v2 use stealth porting, and if this is turned on by default. Thank you.
Message 1 of 5
Accepted Solutions
JamesGL
Master
Re: Netgear Nighthawk x4 ac2350
Hi craigressler,
The router does not use the stealth porting type of firewall. R7500v2 will always response with “reset” packet  if  client send packet to non-opened port.
Message 2 of 5
All Replies
JamesGL
Master
Hi craigressler,
Message 2 of 5
JamesGL
Master
Hi craigressler,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 3 of 5
craigressler
Thank you James, your answer was very helpful. Have a great day.
Message 4 of 5
JamesGL
Master
Hi craigressler,
Thank you for the feedback. We encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2307 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
