- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear Nighthawk
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear Nighthawk
Hi,
Looking into getting new router, Which one is the best one?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear Nighthawk
A lot more info is needed.
You might not want the peak fastest router if you have a large home and need more coverage.
So some more info.
What size is your home?
What are the interior walls made of?
How many devices are you using?
What are you using them for (gaming/streaming/etc)
Whats your budget?
its pointless for us to recommend a $600 RAX200 if you're budget is $200. Then the R7800 would definitely be the choice.
Or if your home is 4000-5000sq ft, a mesh system is going to provide better coverage than a single router solution.
so details help us to help you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
hi,
my home Double story, walls are plaster wall. I will have my tvs and Security camers . the rest is on wifi.
using it for games and downloading, happy to pay around $800
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
WiFi Range Extenders: Boost Your WiFi Range | NETGEAR
and
Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
