- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear Powerline 1000 stops working
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have two smart TV's in my house, and I use PL1000 for both instead of cables. It has worked well for half a year, but during the past month I had 2-3 times suddenly no more internet. I tried to take both PL1000's out from the electrical outlets. Shortly afterwards I connected again and the TV's worked well again. The PL1000's get very warm, maybe is that the reason that they suddenly stop working?
I have three PL1000's: One connected to the wifi router and one for each smart TV. I did not plug into extention cords etc. I have a very good fiber internet with as much as 250 Mbps.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Both are going down at the same time?
Many things can impact powerline devices because they suffer from interference from other electrical devices.
Any device that injects interference into the powerline system can cause issues.
This includes:
cheap cell phone chargers
electronics going bad or cheaply made
high draw appliances
old/bad/poorly done wiring
gfci outlets
arc fault breakers
surge protectors
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
This includes:
gfci outlets
arc fault breakers
surge protectors
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear Powerline 1000 stops working
In the case of problems one often start to consider buying something better. Is the PL1000 good enough, or would you recommend a better one, maybe because of my 250 Mbps line?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I doubt if "faster" powerline would help. The ports on the PL1000 are Gb, rather than the 100 Mbps of older plugs.
Powerline will never reach those speeds anyway, and even 100 Mbps plugs should be fast enough for smart TVs.
I have used slow plugs for years on a VDSL line (max speed 60 Mbps) without problems.
