Orbi WiFi 7 RBE973
Reply
Netgear R6800 VPN broadcast network
aless
Hello,
Is it possible to set up VPN servis to me same IP address as my home network (i.e 192.168.1.x), right now I get IP from different network (192.168.2.x)?
I need this for broadcasting service for control over my AC?
Model: R6900|Nighthawk AC1900 Smart WiFi Router
Message 1 of 4
Accepted Solutions
TheEther
Guru
Re: Netgear R6800 VPN broadcast network
I have never seen any directed broadcast forwarding options on consumer grade routers.  It has long been a best practice for routers to drop directed broadcast due to concerns about DoS attacks.
Message 4 of 4
All Replies
TheEther
Guru
It depends on the type of remote device.  If it's iPhone, then it only supports TUN style OpenVPN, which uses a different subnet.  You need a device that supports TAP style OpenVPN.
Message 2 of 4
aless
Thanks for the info. I use android (so TUN is my only option) - there is probably no broadcast forwarding options on my router to solve my issue?
Message 3 of 4
TheEther
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3181 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
