Reply
Netgear R7000 Cable internet fallout
Honis
Hi, I have a R7000 router. I have plugged my home computer with cable all the time with no trouble. In addition I have now also plugged an Xbox to the router with cable and are getting soe issues wit my home computer. Every time I wake up my home computer after it has gone to sleep after I have been out ore something I have to deactivate and activate my ethernet to get the signals. Ore turn the computer off and on. Any tios what has happened and how I can fix it? Thanks in advance!
Message 1 of 4
JamesGL
Master
Re: Netgear R7000 Cable internet fallout
Hi Honis,
Please check the properties of your adapter. Make sure to uncheck the " Allow the computer to turn off this device to save power".
  1. Click the Power Management tab.
  2. Uncheck the Allow the computer to turn off this device to save power check box.
JamesGL
Community Team
Message 2 of 4
Honis
Hi, not sure what you mean?. When my computer goes to sleep it does not seems to recognize the network and can not identify it. When I deactivate and activate the ethernet in network and sharing center in windos it comes back up. Strange.
Message 3 of 4
IrvSp
Master
Although you have not said what OS you are running, if Windows, this is a common complaint. Fix mentioned above is the usual fix, although some have had to do the opposite, see http://superuser.com/questions/889297/issues-with-internet-after-sleep-mode for instance.
You can also Google "lose internet connection after sleep" and see a lot more answers/discussions.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1589 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
