Reply
Netgear R7000 Hissing under wireless load
coco1458
I've noticed that my R7000 has a hissing sound when the wifi is under heavy load, what would be my options? (as my warranty is out of date)
I've tried to contact RMA and they've pretty much told me to send my router in (at my own cost) + I don't have a backup router.
Message 1 of 4
Retired_Member
Not applicable
Re: Netgear R7000 Hissing under wireless load
Make sure you're using the 3.5 amp Power Adapter. Set Mode(s) no faster than clients. I would suggest trying the latest FW because it allows you to lower output but it's riddled with other bugs. If not using 1300 on 5g try a different channel.
Message 2 of 4
coco1458
Tried with no luck, the hissing sound seems to be something to do with the capacitors used. Oh wells, I guess i'll just have to stick with it until I find a new router.
Netgear's RMA process is silly, making me pay to not have a router for a week
Message 3 of 4
Jim769
Luminary
That sound is called coil hum and is annoying but harmless and does not affect performance. Why some routers do it and others don't is anyone's guess if it bothers you that bad try for a RMA or try a different router that's about all you can do.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2032 views
  • 0 kudos
  • 3 in conversation
Announcements
