Reply
Netgear R7000 speed dropped
Mabilarg
Follower
I was having some internet issues today which resulted in resetting of the comcast router as well as the never router that is connected. In June I used to get 173mbps with 6 up speed with the netgear wifi but the download speed for some reason has dropped significantly to an avg of 25mbps with 6 up speed. Does anyone know whats caused this? The original Wi-Fi with xfinity seems to be working fine because the speed is at around 160mpbs when I'm in the room, I'm using the netgear router to reach rooms that are further away
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 2
Re: Netgear R7000 speed dropped
Did you reboot the whole network ion the correct order.
  • Turn off and unplug the modem.
  • Turn off the modem router and computers.
  • Plug in the modem and turn it on. Wait 2 minutes.
  • Turn on the modem router and wait 2 minutes.
  • Turn on the computers.
What is this Comcast router. If it really is a router, and not just a modem, then you may need to reconfigure it to be in modem only mode, or put the R7000 into access point mode.
Maybe your resets wiped out those earlier settings.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 268 views
  • 0 kudos
  • 2 in conversation
Announcements
