Reply
Netgear R7000P slow wifi
Helpmewithwifi
Hi,
So, I just recently purchased a brand new R7000P Netgear Nighthawk. Setup was easy and the streaming has been pretty stable but the wifi has been extremely slow and frustrating.
Not only that, I can't see the Netgear 5G either. It just lags and sometimes the connection just dies (only 3 things are connected thus far to it). I'm not sure if I missed a step or 2 but I need assistance.
Please advise.
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 6
nyclewis
Star
Re: Netgear R7000P slow wifi
I had to downgrade my firmware (available on their site) to v1.3.1.26 and turn MU-MIMO OFF to get reliable wifi. Just a suggestion.
Message 2 of 6
Helpmewithwifi
Steps please? Downgrading, wouldn't that be a safety hazard?
If that's the case, is the nighthawk worth it?!
Message 3 of 6
myersw
Master
Safety hazard? Potentially depending on if they have even put any security patches in.
IMHO the nighthawk is not worth the firmware agravation folks are going through. My r8000 and r8000p never got stable firmware so I went elsewhere. In my case away from consumer grade routers as they all seem to have similar issues.
--Bill
ISP Comcast, Modem-Netgear CM1150V, Router-Unifi Security Gateway-Pro4, AP-2 Unifi AP-LR
Tesla > Edison
Message 4 of 6
do you have one of these setups where the router is separate from the wireless access point?
Which AP you use for stable Wifi?
Message 5 of 6
I had issues with r7000 when first bought.
Try this tell me what happens
1) install latest firmware
2) reboot
3)reset to factory settings physically (using the reset button on the device)
4) reboot
5) setup as new device (don’t import previous setups or backup files)
tell me what happens,
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1030 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
