- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear R7800 Firmware 1.0.2.76
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020/04/11
EXACLTLY SAME PROBLEMS WITH TE NEW FIRMWARE v1.0.2.76
Wifi drops in AP MODE / unable to use AP MODE
R7800 v1.0.2.76 firmware always contains BUGS
Reset the router. Still the same problem.
Back to firmware v1.0.2.68 and everything is OK again
So dont use the v1.0.2.76 firmware
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Netgear-R7800-Firmware-1-0-2-74/td-p/1975555
Hello from France 😉
Before, I used AP MODE with v1.0.2.68 and it works perfectly...
yesterday, I have upgraded to the new firmware v1.0.2.74 : lost WiFi connections + no internet access + reboot + restart... 🙄😒🤔🙁
So... Keep going : Fresh install... RESET rooter... v1.0.2.74 fresh start & fresh clean install AP MODE...
problems are exactly the same...
In fact, with the v1.0.2.74, the R7800 rooter works correctly a few minutes, and after,
lost WIFI connection + no internet + reboot 😕 restart, works a few minutes... and again and again... I try many firmware flash v1.0.2.74 thru the web interface + clean RESET ... same pb...
R7800 v1.0.2.74 firmware is OUT 🙄
R7800 v1.0.2.74 firmware contains BUGS 🙁 even with a RESET & a fresh install...
So ... Revert back to v1.0.2.68 firmware :
WIFI + INTERNET + AP-MODE
WORK PERFECTLY
BYE
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear R7800 Firmware 1.0.2.76
I also experience wifi droppings since I have installed the latest firmware. I do not use it as an AP, but as normal router and have the same issue. Hopefully they will fix this soon with a new update.....
- Mark as New
- Bookmark
- Subscribe
- Permalink
I also have the same firmware and an using it in the AP mode.
The R7800 hangs and reboots randomly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just to add information.
1.0.2.74 also has the same problem.
Now I've reverted to version 1.0.2.68.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm on 1.0.2.74 in AP mode and have never had a problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello from France,
I have exactly the same problems.
Router restarts randomly, since 1.0.2.74.
I have downgraded to 1.0.2.68, no problems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've noticed several problems to .76 reported in the forum.
I noticed once I went to it, all connections, local and internet of course would drop, which has never happened in my history with this product. I rolled back to .74, and it still kept happening. I've seen it happen only once with .68, and what is weird is that .74 never used to do it either. I wonder if I should factory reset and then fresh update to .76 because something clearly has gone astray judging by all the issues listed in this and other threads.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tried it a 2nd time after a factory reset. No dice. .76 so far in all the years I have had this router is by far the worst firmware update I've seen. ...in fact I don't recall having much problems before this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know how if you like it
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok so awhile back what I did was factory reset by holding a toothpick in the reset button for half a minute just to be extra sure. When it asks you to update to the latest firmware (.76) I said yes.
Now here's the kicker: do NOT restore your saved settings. Put them in manually one by one.
I haven't had any issues at all now. You can see my past posts that .76 was giving me lots of problems until I did this (I discussed it in several threads, not just this one.)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
That link does not work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
1.0.2.78 has exactly same bugs....
Even a fresh and clean install...
- Mark as New
- Bookmark
- Subscribe
- Permalink
NETGEAR R7800 firmware v1.0.2.78 issues
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Netgear-R7800-Firmware-1-0-2-78/m-p/2017841/...
