Orbi WiFi 7 RBE973
Reply
Netgear R7800 ethernet throughput issues
DaveSanders
Initiate
Netgear Nighthawk R78900 V1.0.2.52 firmware Windows 10
The R7800 is installed after an Arris Surfboard SB6183 cable modem.
Eperienced thoughtput issues about 2 months ago when the download speed dropped from ~180Mbps to ~93Mbps. Direct connection to the Arris moden restored the speed to ~180Mbps.
After checking R7800 settings I disabled Qos and the problem was resoved.
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 4
Accepted Solutions
myersw
Master
Re: Netgear R7800 ethernet throughput issues
Sounds right to me. QoS will slow a connection down which is what you experienced until disabling QoS. QoS will not allow full speed of the Internet connection.
Message 3 of 4
All Replies
microchip8
Master
yes, and? you found the problem so what else do you want?
Message 2 of 4
myersw
Master
Message 3 of 4
DaveSanders
Initiate
Hi Bill, what is strange is that I have had QoS enabled for a condiserable time prior to my experiences with the poor throughput performance and was getting around ~180Mbps download.
Dave
Model: R7800|Nighthawk X4S AC2600 WiFi Router
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1998 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
