- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear R9000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I ended up calling support. Apparently there was a wrong IP address in the wrong place that was causing issues. I ended up doing a hard reset and using Genie to set up again. Seems much better for now.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear R9000
Welcome to the community, @Eckhardfamily5
Did you try to other ports on the router?
How about changing the cable?
Can you check if you'll experience the same problem if you use a different device connected through wired?
It might be the LAN card on your Mac computer.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
