z0mbie
Dec 12, 2022Follower
Netgear WN3000RPv3 as an Extender
Hi,
I have the above extender & its setup and connected to the Router but only my mobile phone can connect to it my PC says "Can't connect to this network"
I've clicked on update f/w via the internet, still no go, I may try manually downloading firmware?
Has anyone else encountered this issue please?
Thanks
Z
1 Reply
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
