Reply
Netgear Wifi routers and time sync issue behind AT&T Gigiapower modem
smartloom
Guide
I can reporduce issuse on all models.  R8500, R8000 and R7000.  If you put AT&T gigiapower modem in DMZPlus mode to forward all traffic to your netgear router it will block NTP UDP port.  AT&T published that article saying that they will block time sync.
https://www.att.com/gen/public-affairs?pid=20879
What do we do if we want to use DMZPlus on new routers?  Thanks to @JamesGLas he helped me to work with Netgear support and they did provided me special firmware for R8000 and R7000 but know I need the custom firmware for R8500.
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 1 of 4
William10a
Master
Re: Netgear Wifi routers and time sync issue behind AT&T Gigiapower modem
There should be a way the you could use a gps signal to time lock a netgear router
Message 2 of 4
smartloom
Guide
You can't change anything for time configuration on the router other than timezone.
Message 3 of 4
William10a
Master
I know you are out luck when the able to set a simple time and date server chance as standard feature is not allow in the firmware why made were behind a curtain type of modem would add a feature that cause's problems. Even a way of using gps device would give you time and date and it could made into the router.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3677 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
