- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear X10 R9000 not broadcasting WIFi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All
I have a Nighthawk X10 R9000 router and i am attempting to connect 2 No. Panasonic wifi enabled cameras (Lumix TZ95 and Lumix G7) to the router. However, both cameras can not detect the SSID of the router although other devives (ipads etc) are able to do so. I have checked that the SSID Broadcast option is correctly set to 'on' through the router settings menu.
Does anybody have any ideas of additional settings that I may need to make/try so the SSIDs are visible to both cameras?
Thank you in anticipation
Hoglets
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear X10 R9000 not broadcasting WIFi
I'd check with the camera manufacturer. If everything else can see the network, it seems to indicate an issue with those devices.
Maybe they require specific channels used for wireless or need their own hub.
