- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear hawking R7000, no connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello. I have a huge problem and I hope you guys can help. I have the router Netgear Hawking r7000|ac1900 but I have no internet connection at all. Yesterday I tried to do a system update through my phone on their app NightHawk. But it said the update failed and now the connection doesn't work. The power lamp is just blinking white and there is no wireless connection. There is no connection even if I use cable from the router to my PC, so I can't fix it through routerlogin.net. I have tried to restart and reset the router but nothing works. I would really appreciate it if you could help me. I'm sorry for the English, I do hope it's understandable tho.
On the picture you see powerlamp, it's the one that is blinking white. No other lamp is lit
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] Hawking [...]
??? "Nighthawk"?
> [...] The power lamp is just blinking [...]
You may be a candidate for the TFTP recovery scheme. See, for
example:
https://community.netgear.com/t5/x/x/m-p/1622096
To get the firmware kit, visit http://netgear.com/support , put in
your model number, and look for Downloads. (For older versions, under
Firmware and Software Downloads, look for "View Previous Versions".)
Find the kit(s). Download the kit(s) you want. (Normally, then, you'd
read the "Release Notes" file for instructions, but you'll be trying the
TFTP recovery scheme instead of a normal update.) The User Manual for
the device is in that same neighborhood, too (under Documentation).
> [...] I'm sorry for the English, [...]
Not a problem. (Better than many natives.)
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] Hawking [...]
??? "Nighthawk"?
example:
