Toan
Apr 28, 2017Aspirant
Netgear logging not working
I enabled all options using Netgear Genie for logging but none of the sites I visited on the allowed/blocked sites would show up in the logs. Below is the list of options I enabled:
Attempted access to allowed sites
Attempted access to blocked sites and services
Connections to the Web-based interface of this Router
Known DoS attacks and Port Scans
Port Forwarding / Port Triggering
Wireless access
-Toan
Thanks for the reply James. My router started logging again after I added a couple new entries, save, and did a complete shutdown/restart.
- JamesGLNETGEAR Employee Retired
Hi Toan,
1. Did you configure block sites?
2. What is the firmware version of the router?
- ToanAspirant
Hi James,
Yes, I blocked severals sites (Security - Block Sites) and my firmware version is V1.0.3.36_1.1.25
-Toan
Hi Toan,
I have the same firmware but my logs shows sites I visited that are blocked and allowed.
Try to reset the router and reconfigure it manually.
